I shel modify it tomorrow and see how it goes. We are staying in it in the garden next week because we should be on the Isle of Man for the TT. We are going to be sad and watch TT videosTRUNNIONMAN wrote: ↑Thu, 28 May 2020, 9:36 pmYes I made my one to fit around the pole so as to stop it from swinging from side to side
Roof lifter
Re: Roof lifter
Re: Roof lifter
I have a roof lifter for a red roofed portafold. If you want me to send you the list of parts message me and I will send you all the links. . My name is Mark Gable
Re: Roof lifter
Hi mark, have you made a roof lifter. I really need one as got a injured shoulder which make me can’t lift the roof. Can I have your mobile please. Thank you
Re: Roof lifter
Hope this will help
Ebay item no 124603552173
SUPERB EASY FIT MAST HEAD PULLEY FOR UPTO 2 INCH MASTS-TAKES 4-5mm Rope-SEE LIST
Ebay item no 113961621886
MAST SET ALUMINIUM 15 Foot (5 x 3Foot sects) 1 1/2 inch SLOT TOGETHER
Ebay item no 123487291144
Square Mast Base plate(Galvanised) 23 cm x 23 cm ( stub is 60mm high by 45mm dia
(The 3 items above come from the same supplier. The masts are priced for 5 x 3ft posts but he will sell you 3x3ft posts plus the pully for a joint purchase. Saving on postage. You may find you want different lengths or thickness. Depending on what your storage space is. I was very limited so went for 3ft lengths. I purchased 2 inch but think smaller diameter might work just as well and be lighter)
Ebay item no 313011707737
Manual Hand Winch 600LBS Boat Trailer Caravan Marine Pull NO CABLE
(I recommend not using steel cable as it is too hard. I used the climing rope which worked just as well)
Ebay item no 132887115305
POLYPROPYLENE ROPE BRAIDED POLY CORD STRONG STRING BOATING CAMPING SAILING YACHT
Ebay item no 373228285182
6MM 316 STAINLESS SNAP HOOK WITH EYE CARABINER CLIMBING & HIKING
I think the Ebay item numbers are correct
If you want more information please contact me direct on messenger.
