Hello
I own a Portfold made 1974.
I am trying to change to aluminum rims "ultralite" but have a problem. When I tighten the wheel nuts, it is not possible to move the wheel. I need spacers? Anyone had the same problem and need to supplement with spacers?
Is there any spacers to portafold who fits ?
Kind Regards
Anders
Do I need spacers ?
Do I need spacers ?
- Attachments
Kindly regards
Anders
Anders
Re: Do I need spacers ?
Any spacers designed for Mini's should be OK, but bear in mind, you'll need to extend the studs as well. You'll have to knock them out and replace with longer ones to ensure you have enough to screw your nuts on to.
Thanks I need longer studs.
Regards
Anders
Regards
Anders
Kindly regards
Anders
Anders
Do a mock up of how your wheel is going to be. Put some pretend spacers behind the wheel to space it out until you get a nice gap between the tyre and whatever it's rubbing on. Then you know how wide your spacers have to be, and how much longer your studs are going to be. From memory I think the studs are 3/8" studs, like Mini ones. So knock a stud out (put two nuts on one stud and hit them to knock the stud backwards out of the hub) and then measure it tip-to-tip and add on the size of the spacers you're going to use.
Thanks for answer.Admin wrote: ↑Mon, 20 Jul 2020, 12:15 amDo a mock up of how your wheel is going to be. Put some pretend spacers behind the wheel to space it out until you get a nice gap between the tyre and whatever it's rubbing on. Then you know how wide your spacers have to be, and how much longer your studs are going to be. From memory I think the studs are 3/8" studs, like Mini ones. So knock a stud out (put two nuts on one stud and hit them to knock the stud backwards out of the hub) and then measure it tip-to-tip and add on the size of the spacers you're going to use.
Yes I have measured how wide the spacers need to be. And I have now ordered spacers with longer studs.
When I remove the drum brakes, do I also need to remove the wheel bearings?
Do I need to buy new wheel bearings? Just in case if they need to be replaced?
Where do I buy some new wheelbearings for a Portafold yearmodel 1974?
Kindly Regards
Anders
Kindly regards
Anders
Anders
No, the studs are just in the drums. If you put a nut on the end of the stud before knocking it out, and use a block of wood, and if you're careful you won't damage the old stud and it should knock out alright.
No need to go anywhere near the bearings.
