A fantastic vintage show set in the Wylye Valley (on the A36 west of Wilton, Wiltshire) on the weekend of Friday the 2nd to Sunday the 4th of June 2023.
A great array of retro stalls, a superb bar supplying local ale, the cider bus and quality entertainment. It's very popular and sells out every year. Early-bird ticket prices are available until approximately Christmas.
Buy your weekend tickets and camping pass through their website (link below), then make sure you let me know you're coming so I can set aside enough room for us all in the camping field.
N.B. We won't be in the Vintage Camping area as it sells out quickly and people with modern outfits aren't allowed in, which means we're all separated. Plus there's more room and better camping ground in the main camping field.
If you want to join us, I would avoid driving to the camping field entrance from the A36, it has a bad bottleneck at the entrance to the showground. If you're approaching from the east or south, via the A36 or A303, I would highly recommend that you use the A303 to bring you in through the villages of Bapton and Stockton. This will bring you direct to the camping field entrance, avoiding the bottleneck. If you are approaching from the north west via the A36, I would turn right off the A36 before you get to Codford St Peter and come through the villages of Boyton and Sherrington, this again will bring you in the back way and avoid the bottleneck.
More info and tickets can be found here: www.vintagenostalgiafestival.co.uk
The show address is:
Stockton Park, Stockton, Wiltshire.
The nearest postcode for the sat-nav is: BA12 0SQ
Vintage Nostalgia Festival - 2nd-4th June 2023
