Rubber seals
fuzzyface
Rubber seals
Post by fuzzyface » Sun, 23 Nov 2025, 7:47 pm
Just started (after 10yrs :oops: ) to bring my portafold back into service.
Trying to find out what seals are required as mine are either perished or missing. I've been checking through the forum for details and this is what I've found...
1. Four U section solid rubber seals down each of the four corners of the end panels (that face against the side panel ends).
2. Top of the hull at each end where the end panels sit onto, rubber strip ~ 1/4" by 5/8"
3. Solid rubber faced foam described as "short end-pieces closing the gaps at each end of the front wall, each end of the rear & each side of the door"
4. Foam strips running along the top of the side walls that the roof sits on (as advertised in the parts section).
5. Can't find any reference to seals around the doors, aren't there any?
6. Is there anything sitting on top of the end panels? I've some hideous lumps of foam that don't look correct but also some black foam on the outside of the four roof catches that does look original.
Any thoughts, comments or confirmation appreciated that will help me find what I need.
Steve.
